This Week in Beagle #27
Hello everyone. I ended up skipping some weekly updates since there was not much to talk about. Maybe I should make this series a bi-weekly thing instead of weekly updates. Anyway, I will be going over things from all the missed weeks as well. Let’s get started.
Zephyr
Add MAIN domain USARTs for PocketBeagle 2 M4F
The initial support for PocketBeagle 2 M4F landed a while ago. This support was quite limited, and is being expanded with time. Initially, I thought that the M4F, which is from MCU domain, did not have access to the MAIN domain peripherals. However, this assumption turned out to be wrong.
The cross-domain peripheral support varies a bit, but for the most part, it is possible to use MAIN domain peripherals from MCU domain. This meant that more of the PocketBeagle 2 header functionality could be used from the M4F core. However, the current base devicetree for AM62x M4F did not define nodes for the MAIN domain peripherals.
Since the initial support for M4F was limited to MCU domain UARTs, I started by adding support for MAIN domain USARTs. It is important to note that the M4F does not have access to the interrupts for the MAIN domain USARTs. Thus, only polling based usage is supported.
I have also started following the Linux kernel devicetree nomenclature of having the domain prefix in the peripherals. I will rename the already existing peripheral nodes in the future.
Checkout the full PR for more details.
Add I2C support for PocketBeagle 2 A53
The initial support for PocketBeagle 2 A53s was merged recently. This allows running ZephyrRTOS on the main A53 cores instead of Linux. It uses the same u-boot as Linux, but can be great in very special purpose and high performance real-time use cases.
The initial support was limited to just USARTs. However, I have created a PR to enable I2C pins on the header. Checkout the PR for more details.
BeagleBoard Imaging Utility
macOS signing
For the longest time, the BeagleBoard imaging utility was not signed on any platform. This was a big problem in the case of macOS since without proper signing and notarization, it can be quite confusing and difficult for non-tech savvy people to get it to launch. Since I do not own a mac, it was also quite difficult to test, and thus, I have been mostly ignoring it.
However, with the help from Deepak, I was able to get the macOS packages properly signed and notarized. So, hopefully, this will help attract more users, which in turn might become contributors.
The first release with proper signing is v0.0.6.
Ubuntu 22.04 support
Since switching the development to GitHub, I have been using ubuntu-24.04 runner for Linux builds. However, it was recently brought to my attention that this makes the package not work on older systems such as Ubuntu 22.04, due to glibc. For now, I have switched to building on ubuntu-22.04 runners. However, maybe it would be a good idea to either use Debian docker containers to build the image, or use musl rust targets and do static linking of libc.
GPT partition table support
Most of the BeagleBoard Linux images used the MBR partition table, so GPT partition table was not supported in the BeagleBoard Rust Imager. However, it recently came to my attention that the BeagleV-Fire images use the GPT partition table, and thus was failing. However, I have now added initial support for GPT, so hopefully everything works fine (I have only done Linux testing).
USB DHCP Option
Thanks to the amazing work by Robert, network sharing over USB works great on Windows and macOS. However, it might not always be desirable to have USB NCM support. Thus, it is not possible to enable or disable this from both the CLI and GUI.
Refresh button for Image list
BeagleBoard Imager downloads the list of images and firmwares at the start of each run. This sometimes can go wrong because network requests can fail. Earlier, the only real way to fix this was to relaunch the application, after ensuring a working network. However, I have now added a refresh button in the image selection page that allows manually refreshing the list.
This ended up being a bit more complicated than it might first appear since the distro list is not a single remote list. Instead, it is a result of merging multiple seperate lists. So the refresh button only appears at the first image selection page (no sub-pages).
SSH Auth key support
BeagleBoard Imager now supports specifying authorized ssh keys in the UI, similar to Raspberry Pi imager. Most people using ssh will love this option.
Checkout the PR for full details.
BeaglePlay CC1325P7 Micropython support
Unofficial builds for Micropython on BeaglePlay CC1325P7 have existed for a while. However, since the version of Zephyr in upstream Micropython has been updated, I have created an upstream PR to add support for this MCU. Hopefully, people will find it useful.
Helpful links
